Go Back   OC3D Forums > [OC3D] Processors & Platforms > Mainboard & CPU
Thread Tools Display Modes
  #1
Old 14-01-20, 10:46 AM
Leemundo Leemundo is offline
Newbie
MSI gaming edge 12pin power connectors
Hi all.
In regards to the 8+4 pin power on a lot of modern motherboards, are these both needed to be powered or can you use just the 8 pin? Reason I ask is that I'm about to pair this board with a 3700x (upgrading from a 7 year old system). My current Corsair cx650w PSU only has the 8pin.
If so I'll still consider upgrading it but at least I can do it at a later date when funds are more freely available.
Thanks in advance, the help us much appreciated. (Looking to purchase tonight).... 😬
  #2
Old 14-01-20, 11:10 AM
Dark NighT's Avatar
Dark NighT Dark NighT is online now
OC3D Elite
No need to worry here at all, the 3700x is quite power efficient and even with LN2 overclocking that thing to its absolute max, it will not draw enough power to max out a single 8 pin connector.
Just plug in the 8 pin only, you will be totally fine. as for upgrading to a 12 or 16 core, only if you overclock, then maybe the extra 4 pin can bring some more stability for daily use, otherwise the 8 pin is still fine for stock use.
__________________
Rig: Cpu: AMD R7 3700X. Mobo: Gigabyte X470 Aorus Gaming 7 wifi. Ram: Gskill Royal Silver 3200mhz cl16: Gpu: Msi RTX2070 Armor. Asus Xonar STX II.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
