Thread Tools Display Modes
  #1
Old 16-06-19, 04:50 PM
tinytomlogan's Avatar
The Guvnor
TTL's SL600's
Thought Id drop this in here to start the conversation.....
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #2
Old 16-06-19, 05:07 PM
tgrech tgrech is offline
OC3D Elite
Very much looking forward to this, have to admit I'm a faux-carbon fibre fiend and the idea of using actual stuff has fascinated me for a while, I mostly like the clean minimalistic pattern too though I guess. But yeah, cars & computers are powerful anti-depressants, something very easy to get excited about and spend hours on.
  #3
Old 16-06-19, 05:13 PM
The Guvnor
We need a like button so bad
__________________
  #4
Old 16-06-19, 07:24 PM
Pugsport Pugsport is offline
Advanced Member
what type of carbon fibre are you planning on using? (which style weave pattern)
ive wanted to make a full carbon fibre version of the Corsair 780T or the Silverstone Raven 2 case but what with my other projects going on like the winter desk build and my summer Volkswagen Transporter rebuild i just dont have time at the moment to start anything else.
here is a Renault 5 GT Turbo badge i made a few years ago, sadly i can not find the photos of finished up and flow coated. all i can find is photos of it out the mould and then trimmed up but you get the idea. this is resin infused and not pre preg so it took a fair amount of time to get the weave straight.
  #5
Old 16-06-19, 11:55 PM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
This is gonna be so epic cant wait Guv!
__________________
DRAGON'S MIST
Coolermaster H500P White ARGB=AMD Ryzen 3700X=MSI Prestige X570 Creation=Intel Optane SSD 9 480GB PCIE=32gig 3600Mhz White Dom Plats RGB= Sapphire RX5700XT Nitro Plus=Coolermaster ML360R ARGB=MSI Optix MPG341CQR=Roccat AIMO 122=Corsair Force LS 960GB=Roccat Kone AIMO White=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with RBG strip=Windows 10 Pro=Thrustmaster T16000M HOTAS=Razer Firefly RGB CE=Chasepower Pure Sinewave UPS
  #6
Old 17-06-19, 05:46 AM
Eddie long's Avatar
Eddie long Eddie long is offline
Advanced Member
Nice idea i'm looking forward to this one , i loved the corsair's prototype of 780t well except the colour
As for an alternative name how about Phoenix maybe quite fitting
__________________
Life isn't always a bowl of cherry's.
Sometimes it's HARD WORK
  #7
Old 17-06-19, 09:19 AM
AlienALX's Avatar
AlienALX AlienALX is online now
OC3D Elite
Still love proper carbon fibre. Looking forward to this dude that's a nice case to start with too
Or should I say start with two?
__________________
If you don't like what I post don't read it.
  #8
Old 17-06-19, 09:44 AM
The Guvnor
One will be white, one will be carbon.
The carbon is 2/2 twill and its infused not prepreg as we are laminating on top of the standard the standard panels to save tie and the fact we dont plan on doing loads of these.
Might be a one off, might end up making a couple others later, dont know yet. Depends how hard the lower roof panel 'arms' are down the side (long and thin so a pitfa)
__________________
  #9
Old 17-06-19, 01:28 PM
AlienALX's Avatar
OC3D Elite
My fave is yellow Kevlar. Do they do that also?
Just wondering like as I'm not doing another case mod for at least the foreseeable.
__________________
  #10
Old 21-06-19, 08:13 AM
Advanced Member
yer you can get very good surface finish with the infusion process. split mould the lower arms, you may need to use some spray tack to hold the fabric in place at the top while you place the vacuum bag and then once cured you could bond them on to the bottom of the case (they look to be screwed or riveted on to the bottom of the case rather than it all being one piece)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
