Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #11
Old 25-05-19, 10:48 AM
WYP's Avatar
WYP WYP is offline
News Guru
Originally Posted by Duckboy View Post
So in the end I got a Sapphire RX 580 8GB Pulse for £123.11 brand new, for that price I had to!, it should be a big upgrade from my 7850 2gb.
I will be buying a new monitor next week with a bit of luck!
That's an amazing deal. well done.
__________________
_______________________________
Twitter - @WYP_PC
  #12
Old 25-05-19, 11:58 AM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Yeah good going man.Entry level is the only segment where the true deals are now.
__________________
If you don't like what I post don't read it.
  #13
Old 25-05-19, 08:19 PM
cooperman's Avatar
cooperman cooperman is offline
OC3D Crew
£125 for a new 580 thats a bargain! nice one.
__________________
AMD Ryzen 5 2600,Patriot Viper 4 16GB 2x 8GB 3200 Ghz,Gigabyte B450M DS3H,Patriot BURST 480GB SSD x2, MSI 5700, Aerocool White Aero One Mini Eclipse, seasonic m12ii 620w,Deepcool gammaxx 400 v2.
  #14
Old 25-05-19, 08:44 PM
Duckboy Duckboy is offline
Newbie
I know! it was using a discount code tho, I got about £25ish off, they only had 8 of them, gone in seconds.....
  #15
Old 25-05-19, 08:55 PM
Newbie
I might even miss my MSI 7850 2GB lol it's really done me well over 4-5 years, overclocked to 1200/1450 for 3ish years, but I had to dial it back to 1125/1300 lately tho.
Them 7850/70's proper bang for buck back then, hopefully this will last me a good few years too, can't knock AMD's lower end stuff tbh defo for the price!
  #16
Old 15-06-19, 04:45 PM
Newbie
So, I'm having some problems with this card....
It keeps throttling, high temps etc, it's hitting 77c then downclocking from 1366 to 1100~
I've undervolted the card from 1150 to 1050, but it's still hitting 72c in games and throttling, I was using Heaven Benchmark to check stability, ran it for a good hour, temps hitting 66-67, a good stable 1366mhz through out but as soon as I fire up a game it hits 70c+ then starts throttling again....... Any ideas?
My case is clean with plenty of air flow, v-sync on, limited fps to 60fps too...
I'm not sure what's going on?
  #17
Old 15-06-19, 05:04 PM
tgrech tgrech is offline
OC3D Elite
Usually these cards don't throttle until their temps are into their 80's, sometimes even 90's, are you sure it's not power throttling? This might help https://community.amd.com/thread/220803
  #18
Old 15-06-19, 05:33 PM
Newbie
Thanks for that link, I'll check it out, I guess the first thing is then is to uninstall afterburner.
I just don't get hours after hours of testing, low temps, no throttling, as soon as I game... bam! throttling and higher temps.
I'll try upping the power limit and report back.
Thanks for the help!
  #19
Old 15-06-19, 11:06 PM
Newbie
Well the power limit didn't make a difference, still dropping down to 1100~, I'm really quite stuck.......
I might buy a new cooler for it seen as I got it so cheap.......
any other ideas anyone?
  #20
Old 16-06-19, 07:37 AM
AMD Enthusiast
Could try updating drivers or using a slightly older one and maybe updating the GPU bios.
Other than that I would say return and replace.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
