Thread Tools Display Modes
  #21
Old 30-04-13, 07:51 PM
Sir-Weasel's Avatar
Sir-Weasel Sir-Weasel is offline
Member
Wow that is going to look so good when it's done,
the awesome rad placement a fractal desing define r4 is it going to get any better then this. This really is best storage build ever.
Alpenwasser you keep amazing me time on time again first Helios and now Zeus.
Keep them updates coming man
  #22
Old 30-04-13, 10:39 PM
alpenwasser's Avatar
alpenwasser alpenwasser is offline
OC3D Elite
Hehe, thanks for the very kind words.
As long as you don't need any expansion cards, this rad placement is really quite practical,
especially if you still need a lot of HDD's.
And if you put the radiator more towards the side panel and the case was just a tad wider,
you could even get a full fledged GPU in there (double height card) if you used a flexible riser
connection and angled the cards towards the bottom at 90 degrees. As things are now, I
could most likely fit a single slot card in there with that idea (so, a sound card, for example).
  #23
Old 02-05-13, 09:08 PM
Volume's Avatar
Volume Volume is offline
Newbie
I wasn't here for a couple of days and i have something to see...
Looking good
__________________
  #24
Old 03-05-13, 02:32 AM
OC3D Elite
Looking good
Hehe, I strive to entertain, thanks!
  #25
Old 06-05-13, 06:54 PM
OC3D Elite
The PSU Mount
The PSU Mount
Ok, time for a small update, namely the PSU mount.
External Shot - No Front Panel
As you can see, there's still some refinement required, but this gives you a pretty good idea
about how everything fits together. Since the front panel will hide this anyway, it does not
need to be absolutely perfect.
External Shot - Front Panel Mounted
The 90 degree plug fits just behind the front door, so it does close.
Internal Shot
Do not worry about the cables at this point. I started to sleeve them to get some practice,
and I was not yet aware at that point that I would be completely changing the PSU location.
Naturally, all the cables are way too long now, so I will have to shorten them to get
everything to look neat and tidy. They will still be sleeved with blue paracord though. As
soon as I get my sleeving supplies from Lutro0 I will start with that (same goes for
HELIOS).
That's it for now, thanks for stopping by.
  #26
Old 15-05-13, 10:15 PM
OC3D Elite
Crimping Equipment Is Here
UPDATE
My silicone wires arrived yesterday and today I got my crimper from Lutro0. So I will be starting to adjust the PSU cables over the weekend.
Until then,
-aw
  #27
Old 16-05-13, 06:53 AM
AMD Enthusiast
Very creative thinking on the psu mount! Never would have expected that, only weird part is that it will naturally intake air from it's exhaust
__________________
I am Iron Man.
  #28
Old 16-05-13, 10:37 AM
OC3D Elite
Thanks!
But why would it intake air from its exhaust? The fan inside the PSU is still turning in the
same direction, I haven't changed anything about that. Or are you talking about the case as
a whole?
  #29
Old 17-05-13, 01:39 AM
AMD Enthusiast
Well where it exhausts heat from the back of the psu is where the front of the case is, henceforth the intake from the front will go into the exhaust
Not a big deal but it will collect dust if it is unfiltered.
__________________
I am Iron Man.
  #30
Old 17-05-13, 07:32 AM
OC3D Elite
Ah, now I think I understand what you mean. Actually, the airflow will go from back to
front (intake through radiator at the back) through the case. The air going into the case will
be filtered before it goes into the sideboard. The case will be placed inside that, and I will probably
mount a filtered large fan in the sideboard's back which will supply air to the compartment in
which the PC is. That will allow me to close the sideboard while still allowing the PC to draw
fresh air from the outside.
If that sounds a bit convoluted, it will become clearer once I show the final setup.
Tags
360 radiator, black and blue, fractal design r4, modding
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
