Go Back   OC3D Forums > [OC3D] Forum Teams > [OC3D] Gaming
Thread Tools Display Modes
  #11
Old 05-03-18, 04:32 PM
Bartacus Bartacus is offline
OC3D Elite
Originally Posted by Excalabur50 View Post
You want mine the Thrustmaster 16000m as the joystick comes with a left peice in it and you can possibly still use the TWCS that you put with it with your right hand and Happy Birthday I just turned 51 on Saturday
I have this setup, and while the joystick comes with parts for lefty conversion, the throttle won't work right handed, unless the user is dexterous enough to use controls with a pinkie finger. On the right hand side of the throttle, there are several switches and a button that are meant to be thumb-operated, not to mention it's shaped for left hand use. It would be almost impossible to work right-handed.
__________________
Guts: ThreadRipper 2950X / GB Aorus Xtreme X399 / 64GB TridentZ Royal 3600CL16 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU
Storage: 6TB RAID0 NVME array (ADATA SX8200 Pro 2TB x 3)
Water Cooling: HeatKiller TR4-Pro CPU block / HeatKiller IV GPU blocks / 360mm Darskide LP360 rads x 3 / Heatkiller reservoir
  #12
Old 05-03-18, 05:07 PM
Tolemac's Avatar
Tolemac Tolemac is offline
OC3D Elite
Thats what I saw is the issue with it so decided on the X52
__________________
Build Log: http://forum.overclock3d.net/showthread.php?t=72241
“If you knew the magnificence of the three, six and nine, you would have a key to the universe.” – Nikola Tesla
  #13
Old 05-03-18, 05:11 PM
OC3D Elite
Nice! Enjoy Elite Dangerous, and if you really get into it, enjoy your pending divorce.
__________________
  #14
Old 05-03-18, 05:21 PM
Warchild Warchild is offline
OC3D Elite
Originally Posted by Wraith View Post
Are we going all flight school and forming an OC3D wing. Guess I should start looking at one too, though I'll probs buy the warthog.
Warthog isnt very good for ED, great for everything else. mainly because of the lack of rudder.
  #15
Old 05-03-18, 06:03 PM
Davva2004's Avatar
Davva2004 Davva2004 is offline
OC3D Elite
Leftie HOTAS is going to be difficult, as all the throttle hats are located on the right hand side of the throttle slider for thumb activation and if you swap the stick and throttle sides you're going to have a very angry little finger! Could always go for dual joysticks and reverse one of them.
O7 Commanders! CMDR J€DI
__________________
  #16
Old 05-03-18, 06:20 PM
Tolemac's Avatar
OC3D Elite
Thanks but i'll go for the X52 and use it right handed. The only thing I do right handed is hold my knife and fork or use tools . The problem i'm going to have is shoulder pain as my right shoulder is fudged due do a car accident 29 years ago when I dislocated my humerous and snapped it. It can get very painful especially in cold weather.
__________________
  #17
Old 05-03-18, 08:57 PM
Excalabur50's Avatar
Excalabur50 Excalabur50 is online now
OC3D Elite
Yes you are right about the TWCS mines packed away ATM so forgot what it looked like but a lot of people are finding it better to use dual joysticks and two T16000m's would work well as you can easily convert one to left and away you go
__________________
DRAGON'S MIST
Coolermaster H500P White ARGB=AMD Ryzen 3700X=MSI MPG X570 Gaming Pro Carbon WiFi=Intel Optane SSD 9 480GB PCIE=32gig 3600Mhz White Dom Plats RGB= Sapphire RX5700XT Nitro Plus=Coolermaster ML360R ARGB=MSI Optix MPG341CQR=MSI GK80 Vigor=Corsair Force LS 960GB=Roccat AIMO White=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with RBG strip=Windows 10 Pro=Thrustmaster T16000M HOTAS=Razer Firefly RGB CE
  #18
Old 05-03-18, 09:13 PM
OC3D Elite
Are you handy, as in wood working and things like that? It might behoove you to build a mount so that you can keep your arm lower, with your elbow resting on your chair arm while you play. That made quite a difference for me, even though I went full retard and spent serious $$$ on MonsterTech mounts to clamp to my desk. They cost over double what I paid for my HOTAS, but were well worth it, since I'm not handy at all.
__________________
  #19
Old 05-03-18, 11:05 PM
jimma47's Avatar
jimma47 jimma47 is offline
OC3D Elite
Add me to the list for the OC3D Wing.
I use an X52 - purchased in around 2005 and still going strong although a bit squeaky at times.
The TM 1600s are getting great reviews and are super affordable.
If it's only space sims you play then dual stick is great. You can get a left hand conversion for a lot of sticks including the warthog although it adds to the price. Two TM 1600's would be awesome as they have throttle sliders. I don't love the idea of controlling the throttle with a return to centre stick as you're always having to put pressure on it to fly forward so if you're considering dual stick then the separate throttle control would be good for the wrists. Most dualies use Pitch/Yaw on one stick, Roll/thrust on another. Use a hat for the vertical and horizontal thrusters.
Personally I'd either look at the VKB Gunfighter range or warthog for my next upgrade. In saying this I have Saitek Combat Rudder Pedals so I can go for a rudderless stick. I mainly use the twist rudder in ED but pedals for all other flight sims. I play DCS and IL-2 (both badly) but for immersion you can't beat rudder pedals. I'll see if I can use the pedals for the SRV in EliteI think that would be cool.
The only thing keeping me switching to dual stick is muscle memory. I find it weird because that's not how real planes work. Of course if you've only ever played with a game pad or don't play flight sims then it would be pretty natural to pick up.
-edit - HAPPY BIRTHDAY!
__________________
Rig Gallery - Krusty III
  #20
Old 06-03-18, 12:55 AM
OC3D Elite
There's also the immersion factor in Elite using a throttle, since your avatar uses one.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
