Go Back   OC3D Forums > [OC3D] Processors & Platforms > Mainboard & CPU
Thread Tools Display Modes
  #1
Old 01-08-12, 08:40 PM
TheCrazySquirell TheCrazySquirell is offline
Newbie
2500k or 3570k?
I know Ivy has a 10-15% performance increase clock for clock over Sandy but considering the amount of heat Ivy puts out (OC'ed), I'm not too sure on what I should get.
I'll roll with the stock cooler for a while, untill I can get some money for a Dark Rock Pro Advanced 2.
I just want to know, what CPU will preform better/overclock higher?
I will be getting the Gigabyte GA-Z77X-UD3H so the board should be able to handle better overclocks.
  #2
Old 01-08-12, 08:44 PM
yassarikhan786's Avatar
yassarikhan786 yassarikhan786 is offline
OC3D Elite
Definitely the 3570k. You should be able to OC to 4.5Ghz with much lower volts when compared to the 2500k, but you still need to take into account the silicone lottery
__________________
Motherboard: Asus P8P67 Pro (B3) || CPU: i7 2600k || Graphics Card: EVGA GTX 780 Ti ACX || Memory: 16GB - Mushkin Blackline 8GB + Corsair Vengeance LP 8GB || SSD's + HDD's: Samsung 850 EVO 500GB (OS + Programs) + Caviar Black 2TB (Games + Storage) || CPU Cooling: Noctua NH-D14 || Power Supply: BeQuiet Dark Power Pro P9 750W || Case: Corsair Obsidian 650D || Monitor(s): Dell U2410 + Dell U3818DW
  #3
Old 01-08-12, 08:47 PM
Josh Weston Josh Weston is offline
OC3D Elite
They're both pretty much the same. You'll be able to get 4.5/4.6GHz out the Ivy, and anywhere from 4.7-5GHz on the Sandy. Will be pretty much the same performance. I'd roll with the Ivy, just because the newer motherboards shall be better at integrating themselves with the chip. Ivy also has a superior memory controller, if you ever want to roll with some high-speed (and utterly useless) memory.
  #4
Old 01-08-12, 09:12 PM
Newbie
What a noob... I can't believe I forgot about native USB 3.0 and PCI-E 3.0
Thanks for your help again Josh =)
Tags
2500k, 3570k, cpu, over clock
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
