Go Back   OC3D Forums > [OC3D] Processors & Platforms > Mainboard & CPU
Thread Tools Display Modes
  #11
Old 16-01-14, 04:55 PM
Tiki Tiki is offline
Newbie
You really should, alcoholocaust.
Thanks all of you for the suggetions, but as you can see in the image below I don't much space to work with and moving the GPU to the second PCI-E is not an option since I have a WiFi card down on the PCI slot now. Also, I can't afford a new cooler altogether right now, a small "tower-style" heatsink would be within my budget and my space between and Hyper 212 and my GPU.
Click image for larger version
__________________
Phenom II 965 @ 3.8GHz 1.392v; NB @ 2400MHz 1.200v
Cooler Master Hyper 212+
Gigabyte GA-990FXA-UD3 rev 1.1 (F9)
XFX Radeon HD 5770 @ 915/1300 1.025v
G.Skill RipjawsX 2x4GB @ 1600MHz 9-9-9-26-33 2T 1.500v
Intel SSD 320 40GB & WD Caviar Black 1002FAEX
Corsair TX850M / Corsair 400R / Acer S232HL Abid
  #12
Old 16-01-14, 05:20 PM
NickOmega's Avatar
NickOmega NickOmega is offline
OC3D Crew
Yeah your cooler doesn't direct any air across the heatsinks at all.
I see from your sig you're using a 400R case. I know it's generally frowned upon on here, but would it be possible to mount an intake fan on the side panel while working on a more long-term solution?
__________________
My Twitch Channel
Ryzen 5 2600X -- EVGA GTX 1070 SC -- 16GB TeamGroup Dark Pro 3200mhz DDR4
MSI B450 Gaming Pro Carbon -- Corsair Force MP300 240GB
Seasonic Focus Gold 750 -- Phanteks P350X
  #13
Old 16-01-14, 06:13 PM
Newbie
Yeah, I notice that, only on the VRM/Mosfets HS get some airflow.
I only have some cheap 120mm fans that are not aligned with the HS and even so, the air barely reaches it. I'm buying proper 140mm ones soon for that purpose. Still I would prefer both solutions though.
I found this: http://www.newegg.com/Product/Produc...tem=35-233-021
Two owners confirm that it fits on the UD3.
__________________
Tags
990fx, 990fxa, gigabyte, northbridge, ud3
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
