Go Back   OC3D Forums > [OC3D] Graphics & Displays > Screens and Displays
  #1
Old 01-01-14, 08:51 PM
SeekaX SeekaX is offline
OC3D Elite
120hz monitors
Christmas put some money on my bank account and i considered a lot of things to spend it on, came down to either a proper racing setup or a new monitor. Since pCars won't release for a while and me still prioritizing fps games i decided that a new monitor would be money well spent.
To get some things out of the way.
Yes i am aware that IPS panels look better. Yes i am aware that 1440p panels look better. But i play competitive FPS games and those benefit the most from 120hz panels, so there is no point in trying to persuade me.
I am not a fan of huge monitors, it already breaks my heart to only find 24"+ monitors, i don't have much room on my desk so 24" is as high as i want to go.
So far i've been looking at the BenQ XL2411T and the Asus VG248QE, the specs are pretty similar, the Asus is a bit more expensive, therefore it has a slightly higher refresh rate (144hz) and it would fit with my soon to be secondary monitor, which is also by Asus.
The reviews about the BenQ are very much mixed, some love it, some hate it, i heard it takes some workarounds to get the colors right.
Currently i am leaning towards the Asus, but i am open for other suggestions as well.
Does anyone have any experience with either one of them?
  #2
Old 01-01-14, 09:38 PM
Lazlo's Avatar
Lazlo Lazlo is offline
Advanced Member
If you go for the BenQ make sure to get the second revision. It has 144hz too, and the colours are supposed to be better also.
__________________
"The road to hell is paved with good intention."
  #3
Old 01-01-14, 09:41 PM
Scainer Scainer is offline
Newbie
I've got a VG236h which also had very mixed reviews, but I saw the negativity in regards to the price rather than the quality of the monitor. I.e. For the price you can get a better 60Hz monitor.
The question is whether the extra 60Hz makes the experience better. Well the quality of it makes my other monitor look nasty (LG)
I believe it gives a placebo effect and makes games smoother, or its just that my LG sux.
The only issue I have now is that I'm likely switching to AMD meaning the 3D glasses won't work (not that I use them anyway)
In all honesty I believe the FPS of your games should make your mind up if there is an benefit to have.
  #4
Old 01-01-14, 10:16 PM
OC3D Elite
unfortunately the rev 2 isn't being sold over here
quake - 125fps
cod4 - 250fps
cs - 333fps
bc2 - 120fps
yea i will benefit from it.
  #5
Old 01-01-14, 11:23 PM
Lazlo's Avatar
Advanced Member
If you check the amazon.de page, right on the bottom there is a discussion. And people in it say that recent buyers have received the revision 2 version.
Somewhere else I read that alternate.de has the new version.
It seems in Germany they just didn't ad the "e" to the end of the model name. My guess is that they just ship the new ones, when the old ones are out of stock.
I'm thinking about getting a high refresh rate monitor, too. But I'll try to pace myself until the whole G-Sync thing is sorted out.
__________________
  #6
Old 01-01-14, 11:29 PM
d3rrial d3rrial is offline
OC3D Crew
Take a look at the QNIX QX2710 Evolution 2
its a cheap korean monitor, panel is a PLS Panel by Samsung runs at 2560x1440p and people are overclocking these things well past 100 hz, 120hz is achievable, some have even claimed they can handle 130hz+, but that is panel lottery I guess.
They're increadibly cheap, but that comes at a price: Its likely they will have pixel errors, so look for a vendor that sells perfect screens and guarantees no pixel errors. Backlight bleed is also possible, but there are plenty of guides on how to fix it on youtube.
Just saying if you want both high res and high refreshrate, like I do
Quick edit: The screen is 27" tho. So when you say you're limited in desk space, this could be a problem.
__________________
1D3rriAL4Zx4y4ziAxNUzV9YDD8dpkMupW
i7-8700K | 1080Ti | 32GB @ 3000 Vengeance | ASUS Z370 Prime-A | Carbide 540 | RM1000
960 EVO 500GB | 840 EVO 500GB
4.14.13-1-ARCH
  #7
Old 01-01-14, 11:57 PM
OC3D Elite
i'll check that out, but i'm still not sure if the asus one wouldn't just be the easier choice with better aesthetics.
that one is extremely tempting, but unfortunately not sold in germany. would have to import it, which is mad money.
  #8
Old 02-01-14, 12:01 AM
OC3D Crew
[...]that one is extremely tempting, but unfortunately not sold in germany. would have to import it, which is mad money.
I bought it and I'm German. Yes it has to be imported, but they're still cheap.
Look on ebay.de for a good seller. Don't be fooled tho, some say they have pixel perfect quality, what they actually mean by this tho is up to 5 dead pixels or so, backlight bleeding notwithstanding.
__________________
4.14.13-1-ARCH
  #9
Old 02-01-14, 12:27 AM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Personally I would get the BenQ XL2420T rev2.0 24" TRUE 144Hz monitor, Here's a link to the overclockers store page with a lot of info -
http://www.overclockers.co.uk/showpr...d=17&catid=510
I've seen this monitor in person and it's gorgeous to play on, Highly recommended if your n the market for 122Hz or higher also if you look around you will be able to have it shipped to you in Deutschland
__________________
= Steam/Origin/Uplay - Dicehunter =
  #10
Old 02-01-14, 01:25 AM
OC3D Elite
The VG248QE will be able to upgrade to g-sync
that is a pretty good argument for that one.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
