29-12-19, 08:17 PM
Member
Modded Lian Li PC-O11 Dynamic Home Workstation/Gaming Rig
First things first, an apology to bloodycrashboy whose thread I inadvertently hijacked when I first posted the pics of this - sorry dude, I thought it was a general show off your rig thread at the time so I sincerely apologise for that
Now back to the build...
I went for deliberately understated and clean with this one, the only in case illumination is provide by the three side mounted Raijintek Auras 12's which are a deep purple in colour and the motherboard itself - you'll notice there's a little more than meets the eye when you dig a little deeper however.
Spec wise we have -
- An AMD R9 3900X CPU, it's cooling is provided by a roof mounted Cooler Master MasterLiquid ML360R (non) RGB and three EK Vardar EVO 120ER fans in push configuration.
- A Gigabyte X570 Aorus Master (rev. 1.0) Motherboard.
- A 16Gb (2x 8Gb) Patriot Viper Steel 4400MHz CL19 DDR4 memory kit, these are B Die modules and ludicrously overclockable.
- A 500Gb Samsung 970 EVO Plus NVMe as a Boot/Primary drive and a 500Gb 960 EVO NVMe as a secondary drive, I'll likely replace these with a higher capacity Gen4 drive at a later date.
- A Founders Edition Nvidia 2080, this has been reflashed with an EVGA BIOS which allows the implemention of a custom fan curve and unlocks a higher power limit - it's running at 1645MHz boosting to 2100MHz, the memory is running at an effective 15800MHz with just a 105% Power Limit.
- Last but by no means least, it's all powered by an EVGA SuperNOVA 1000 G3 PSU - all the cable extension are Cable Mod flavoured.
The case itself is a custom modded Lian Li PC-O11 Dynamic, you'll notice the custom front panel (which can also accommodate three 120mm fans) plus internally it now sports a backplate for the rear wall and a floor plate - the case itself is a neutral airflow configuration with the three side mounted intake fans and three radiator fans in push configuration extracting the airflow.
Thermals are excellent, case noise is minimal whilst gaming and virtually silent when working from home - all in all, I'd rate it as being almost top end in spec for a non HEDT platform; it's certainly able to laugh in your face at every task it's given.
30-12-19, 01:32 PM
OC3D Crew
Looks lovely mate!
30-12-19, 02:26 PM
OC3D Elite
Nice looking build, love the look of the case.
Do you know if the viper is B die for the 4400 only or applies to 3600/3800?
__________________
ASUS ROG Crosshair VII wifi | Ryzen 5 3600 | Custom Loop | Patriot Viper Steel 4133 @ 3600 2 x 8Gb | Asus Strix RX 470 | Samsung 500gb nvme | Samsung 1Tb nvme | Samsung Evo 120gb ssd | Seagate Barracuda 1tb storage | Toshiba 1Tb HDD | EVGA 500w | Phanteks Entho Pro Tempered Glass | Windows 10 and Linux Manjaro
30-12-19, 02:34 PM
Member
Originally Posted by You_What?
Looks lovely mate!
Thank you both, much appreciated guys
@RobM, I can confirm both the 4400MHz and 4000MHz 16Gb (2x8Gb) kits are definitely B Die (I own one of each) - I have no hands on with 3600/3800 flavours I'm sorry to say.
04-01-20, 02:38 PM
Member
Meet the new monitor
Just a quick update -
I picked up a new monitor just after Christmas at the bargain price of 200 quid (it's normal retail price is £350ish)
Say hello to the Samsung S27R750QEU Space Saving monitor, spec wise it's a 27" 2560X1440 144Hz VA panel and care of a recent firmware patch now FreeSync/Adaptive Sync - it works flawlessly with my 2080.
Once calibrated the colour accuracy is excellent and the contrast is absolutely spot on; some reviews say it's brightness levels aren't so great, personally I find them to be just right for my taste - I'm one very happy bunny  Just a new a TKL keyboard and a Gen4 1Tb NVMe drive on the To Buy List now.
04-01-20, 06:03 PM
OC3D Elite
Very clean. Impressive job.
Here is the repository of knowledge about memory.
https://www.hardwareluxx.de/communit...12-19.1161530/
__________________
Turbos on an engine is God's way of telling you it ain't got enough cylinders.
05-01-20, 03:17 AM
OC3D Elite
Very very nice! Love that front plate!
__________________
Guts: ThreadRipper 2950X / GB Aorus Xtreme X399 / 64GB TridentZ Royal 3600CL16 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU
Storage: 6TB RAID0 NVME array (ADATA SX8200 Pro 2TB x 3)
Water Cooling: HeatKiller TR4-Pro CPU block / HeatKiller IV GPU blocks / 360mm Darskide LP360 rads x 3 / Heatkiller reservoir
05-01-20, 08:01 PM
Member
Originally Posted by Avet
@Avet, Thank you dude, the time spent hiding the various cables ultimately paid dividends in the final result - I've bookmarked your repository of knowledge for future reference
@Bartacus, thank you kindly sir, the front plate also gives the additional functionality of front mounting fans like the Lian Li PC-O11 Air whilst still keeping the clean lines of the Dynamic - I'm really really happy with the end result
06-01-20, 12:02 PM
OC3D Elite
Its really disgusting how cases have dropped performance now and focused on aesthetics. Adopting Form over function leading to many choked pc builds.
Think the guys at gamersnexus made a campaign to all the brands to start thinking about performance and function of case features once more.
06-01-20, 02:54 PM
OC3D Elite
This case doesn't do that. The modded front panel isn't needed at all, it just looks cool.  Airflow is excellent in stock form with this one. But for crap companies like Corsair, totally understandable.
__________________
Thread Tools |
Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
