Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #1
Old 06-04-17, 04:21 AM
LukasKnd LukasKnd is offline
Newbie
Need help deciding on which video card to buy
Hi guys im trying to decide on which card to buy. Im trying to decide on best price/performance ratio. Here are the choices"
RX480 4gb = 235eur
GTX1060 3gb = 218eur
GTX970 4gb = 179eur
Which would be the best on price/performace? These are the only prices that i can get from my local store
  #2
Old 06-04-17, 04:32 AM
AMD Enthusiast
You can't buy online? Might be able to find some good deals.
I'd get the RX480.
If you don't want AMD, then probably the 970. It's the slowest of the bunch, but if money is an issue you will definitely be more than ok.
__________________
I am Iron Man.
  #3
Old 06-04-17, 04:35 AM
Newbie
yes can't get online those are the only options, so is the RX480 worth to pay 55 euros more than GTX970?
  #4
Old 06-04-17, 04:48 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
The 480 is the quickest card out of what you can purchase so if the fund will stretch to it then yes buy it
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 3700X=MSI MPG X570 Gaming Pro Carbon WiFi=Intel Optane SSD 9 480GB PCIE=32gig 3200Mhz GSkill Flare X= Sapphire RX5700XT Nitro Plus=NZXT Kraken X62=MSI Optix MPG341CQR=MSI GK80 Vigor=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #5
Old 06-04-17, 04:55 AM
Newbie
so rx480 would cost 31% more than gtx970, I wonder what would be the percentange in performance difference between these two cards?
  #6
Old 06-04-17, 05:05 AM
OC3D Elite
From what I remember the 480 performs at about a 1070 so that should give you some indication
__________________
DRAGON'S MIST
  #7
Old 06-04-17, 05:18 AM
Newbie
tried to do some research considering my prices Performace per dollar i think would be the best with GTX970 am i correct?
  #8
Old 06-04-17, 05:26 AM
Vicey Vicey is offline
OC3D Crew
The RX 480 is actually quite a bit slower than a GTX 1070. Between 15% and 50% slower depending on the game:
Rise of the Tomb Raider: 43% Slower
GTAV: 43% Slower
Wither 3: 38% Slower
Fallout 4: 35% Slower
These are the games where it's much closer:
Overwatch: 18% Slower
CS:GO: 15% Slower
DOTA2: 16% Slower
The RX 480 is on average 5% faster than the GTX 1060 3GB but 2% slower than the GTX 1060 6GB.
So it's much more on par with those two. In my opinion I would get the RX 480 out of the three choices from the original post. I don't think the added cost of the GTX 1060 6GB warrants the 2% improvement in performance.
EDIT:// Actually scratch that, after looking at the performance differences between the GTX 970 and RX 480 I would instead get the GTX 970. They perform almost identically (RX 480 wins by 2% averaged) but the GTX 970 is significantly more affordable.
__________________
Intel Core i9 7900X @ 4.7GHz [Delidded & Lapped] @ 1.23v Asus Rampage VI Extreme G.Skill Trident RGB 32GB 3600MHz CL17 Samsung 1TB 970 Pro NVIDIA GTX 1080 Ti FE @ 2GHz Asus Swift PG279Q Custom Water Loop
  #9
Old 06-04-17, 05:31 AM
Newbie
GTAV: 43% Slower
CS:GO: 15% Slower
DOTA2: 16% Slower
Yes but strickly speaking about performace per dollar the gtx970 would be the best choice am i correct?
  #10
Old 06-04-17, 05:33 AM
OC3D Crew
You are correct yes. According to benchmarks the RX 480 is only 2% faster than the GTX 970 in real games (averaged) making the GTX 970 much better in the performance per dollar spent category.
The largest win for the RX 480 is only 14% in World of Warcraft of all games. Most games the difference is 2-3% either to the 970 or the RX 480 making them quite even in my opinion.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
