Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #1
Old 14-05-14, 08:56 PM
gampla gampla is offline
Member
air or watercooling my 7870
would watercooling be better to get my xfx 7870 black edition from 70-75c or could i install better fans to get the temp down
i have a shinobi xl with 4 fans
2 cm sickleflow
1 120mm bitfenix spectre
1 200mm bitfenix spectre
  #2
Old 15-05-14, 07:53 AM
barnsley's Avatar
barnsley barnsley is offline
born in a.....
Not worth it mate. The PCB is most likely custom. You could create a custom fan curve so that the card is a bit more aggressive in cooling itself. I used to have the single fan 7870 and 70c is about normal. The cooler is pretty poorly designed.
__________________
Rig: i7 [email protected]|2x8gb HyperX Fury|Intel z97-AR|Corsair H75| 2x Nvidia 1070 founders edition|Superflower leadex 750W gold|Inwin 904| 970 EVO 500GB m.2|512GB evo 840| Crucial MX 500 500GB|ASUS MG279Q +Acer S240HL| Windows 10 pro, 8.1 pro| Kubuntu LTS
Audio: Silverstone EB01-E+EB03+DT 770 Pro 250Ω+Samson SAGOMIC
Ducky Legend (cherry red)+Zowie AM-FG
  #3
Old 15-05-14, 11:13 AM
tinytomlogan's Avatar
The Guvnor
Try looking at the Raijintek cooler we have just used. I certainly wouldnt buy a whole watercooling kit for such a cheap card.
70C load for a GPU is good though.
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #4
Old 15-05-14, 07:27 PM
Member
if i put better fans in would that bring the temps down?
  #5
Old 16-05-14, 03:16 AM
MadShadow MadShadow is offline
OC3D Elite
You are talking about case fans, right?
Tags
aircooling, water cooling, xfx 7870
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
