Fractal Design Arc Midi Window Panel
airdeano
Press Release
Since the release of the Define R4 and it's windowed side panel, the Arc Midi
shares the same side-panel. part number FD-AC-WND-DEF4-ARC-BL. so the
windowed side panel in now available for the Fractal Design Arc Midi
airdeano
with all the email campaigns, storm your retailers to remind them to get their butts in gear
and get these in for you guys/gals who need them instad of modding your own.
airdeano
jeez. this has been announced for months now, i feel like they are never going to release it :P
thanks for the reply Airdeano. i figured if anyone knew, it would be you
LOL... i lika-da-Fractal
man, get a jig-saw, files and some tape and cut your own...
if it takes you all-day.. so what.. make it your own!
airdeano
what case do you have.. cut it up for practice.. so you might be looking at the
back-side of the motherboard tray, but it is always a work in progress..
if you finally get one.. c'mon back with a display of grandure..
airdeano
airdeano
no case. just a laptop. when i eventually do build my PC (either Black Friday or Christmas) itll be my first desktop PC.
i just saw an ebay seller listing the windowed side-panel for sale. this is a US sale
so it must either be releasing or available. he had 10 and they look to be white
panels.
using part number: FD-AC-WND-ARCB
panels.
Its probably the one for the R4 I haven't seen anything on the Arc Midi's yet
I want it though since I don't use the fan mount, and it'd help with positive pressure.
Sadly the little bro (arc mini) does not get a nice window
yeah, its total suckage for the mini.
so, make one yourself. its not really that difficult. a great modding project.
plus you can have it "your way!" LOL.. really..
display your rig proudly.
items needed:
side panel (of course)
1/8" plexiglass or other clear panel
dremel or jigsaw (20-35tpi blade(s))
double-sided tape
low-tack masking tape (i use the 3M 410)
marker
measuring device (tape, ruler..)
touch up paint (i use the SEM Black Trim Paint similar sheen and color)
just an idea
