Go Back   OC3D Forums > [OC3D] Cooling Forum > Air Cooling
  #1
Old 11-10-21, 10:15 AM
dazbobaby's Avatar
dazbobaby dazbobaby is offline
Member
New Phanteks fans reviewed - Noctua finally defeated?
There's a lot to like about the new fans, especially the noise level.
You can add multiple fans via a daisy chain.
Also included is a physical switch inside the fan hub, increasing or decreasing the maximum fan speed.
Take a look
__________________
  #2
Old 11-10-21, 10:52 AM
Warchild Warchild is offline
OC3D Elite
Originally Posted by dazbobaby View Post
There's a lot to like about the new fans, especially the noise level. They also allow multiple fans to be daisy chained.
There's also a physical switch inside the fan hub, increasing or decreasing the fan speed.
Take a look
Looks like a new king of the hill. Although I do wonder if they would be on par had the phanteks been also 25mm. Might have to check some more reviews but they could be a nice replacement for my Maglev 120s. Just comes down to price i guess.
  #3
Old 29-10-21, 03:24 PM
Deceit Deceit is offline
Advanced Member
Thanks for the video, I have 6 ml120's in my PC and a 140. I put them in so I could have a good black fan. Looks like these should handily beat them and be quieter. Looks like a 100% buy from me .
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
