Go Back   OC3D Forums > [OC3D] General Forums > OC3D News
  #1
Old 22-09-21, 09:33 PM
WYP's Avatar
WYP WYP is offline
News Guru
NZXT delivers increased airflow with their new H510 Flow chassis
An optimised H510 design with improved ventilation.
Read more about NZXT's new H510 Flow chassis.
  #2
Old 23-09-21, 06:11 PM
ImprovizoR's Avatar
ImprovizoR ImprovizoR is offline
OC3D Crew
It's good to see NZXT come to their senses after 5 years or so. The only problem is that at $110 price range, there are far better alternatives and this case is dead on arrival because of it.
  #3
Old 23-09-21, 06:46 PM
Dark NighT's Avatar
Dark NighT Dark NighT is offline
OC3D Elite
I don't think this will be DoA just because it isnt as good as some cheaper alternatives, the aesthetic will sell, it being better then the previous one certainly will help there.
__________________
Rig: Cpu: AMD R7 3700X. Mobo: Gigabyte X470 Aorus Gaming 7 wifi. Ram: Gskill Royal Silver 3200mhz cl16: Gpu: Msi RTX2070 Armor. Asus Xonar STX II.
  #4
Old 29-09-21, 03:07 AM
Deadtroopers's Avatar
Deadtroopers Deadtroopers is offline
Member
Increased airflow - no thanks, it's NZXT: it'll just fan the flames./s
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
