Go Back   OC3D Forums > [OC3D] Processors & Platforms > Mainboard & CPU
Thread Tools Display Modes
  #1
Old 02-08-13, 06:50 PM
Epicness_Zombie Epicness_Zombie is offline
Newbie
Question Maximus VI Hero vs GA-Z87X-UD4H
Hey guys,
At Christmas im planning to upgrade my current PC, with a CPU (4770k), motherboard, RAM (Corsair Vengeance Pro Red - 1600Mhz) and a case (Fractal R4 White window) buti'm not sure which motherboard to get. I'm leaning towards the HERO seeing as I've used Asus boards in the past and I'm mostly going to be gaming. I can get the UD4H at aria for £160 and the HERO for £166, also at Aria. Which one would you guys go with for gaming, as well as a little rendering, 3D editing and programming?
Thanks, ~Alex.
  #2
Old 02-08-13, 07:34 PM
Vlada011's Avatar
Vlada011 Vlada011 is offline
Advanced Member
Maximus 6 Hero.
I think in global ROG make better boards than GIGABYTE.
Softwares are better, probably and voltage are more stable, more settings.
People love that different ROG softwares, I don't know between ASUS and GIGABYTE I have more confidence in ASUS hardware.
That doesn't mean all ASUS boards are better than any GIGABYTE.
But last 5 years ASUS is motherboard leader.
Look only Rampage 4 Extreme, I think that motherboard and 4770K to install inside will boot up.
That's biggest mistake probably in my life because I didn't start with 3930K immediately in October/November 2011. I would laugh to this Haswell comedy and upgrade on IB-E for 150$. Second mistake is when I bought ASUS GTX580 DirectCU II instead of
580 Classified monster.
__________________
Intel® i7-3770K (4.5GHz) + CORSAIR H100
EVGA Z77 FTW
EVGA GTX780Ti 3GB K|NGP|N Classified #33
CORSAIR Dominator Platinum 1866MHz (2x4G
CORSAIR Force GT 120/WD500AAKS
EVGA NEX1500 Classified/Seasonic X-750
CORSAIR Obsidian 650D
Logitech G510/G700/C310/ Samsung P2450H
Tags
asus, gigabyte, motheroard, rog
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
