Go Back   OC3D Forums > [OC3D] Processors & Platforms > Mainboard & CPU
Thread Tools Display Modes
  #1
Old 18-08-10, 06:49 PM
lkwms lkwms is offline
Newbie
I have a new build which consists of:
ASUS P6X58D-E
I7-930
3GB of Corsair Ballistix DDR3 12800
EVGA GTX 465
Windows 7
Running stock, should I ever see the core speed @ 1603.7? At this speed CPU-Z list the core voltage at .944 to .952. Do I have a problem with the board, CPU or no problem at all.
Immediately starting CPU-Z after windows logon the core speed is at 2978.3MHz with the core voltage around 1.25. After about 30 seconds the core speed drops to 1603.7.
Thanks in advance!
  #2
Old 18-08-10, 06:57 PM
thestepster's Avatar
thestepster thestepster is offline
OC3D Elite
no problem mate thats just a power saving mode
__________________
Intel Core i7 @ 4ghz and rising!
Noctua NH-D14 - Samsung F3 1TB - Asus P6X58D Premium - 12GB Corsair XMS3 1600
Zotac GTX580 at 895/1790/4200 @ 1030v (1000mv stock @ 772 core) - Corsair TX850 - Corsair 700D
  #3
Old 18-08-10, 07:05 PM
tinytomlogan's Avatar
The Guvnor
Speedstep to be exact, when the CPU is stressed it will run at the stock speed dude
It only runs at the slower speed when not needed / idle
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #4
Old 18-08-10, 07:06 PM
lasher lasher is offline
OC3D Elite
Yep on idle drop the power and clock speeds down to save a few pennies for you.
When required the clock speeds will ramp up accordingly and so too the power required.
__________________
Biostar Tpower I55, I5 750 @ 4.2Ghz, 4GB Kingston DDR3, Custom water loop - Thermochill PA120.3, Heatkiller 3.0 LC, Laing DDC Ultra, XSPC res top, XSPC white hose, Asus 5870, Antec Quattro 1000, Lian Li PC-X2000, Win7 ultimate.
  #5
Old 18-08-10, 07:50 PM
Newbie
Thanks for the responses. I thought I had a defective component.
Now I just need to make sure I don't screw something up with my first OC.
  #6
Old 18-08-10, 09:13 PM
AMDFTW AMDFTW is offline
OC3D Elite
if you are overclocking then turn it off fella
  #7
Old 19-08-10, 08:40 AM
SnW SnW is offline
OC3D Elite
Well keeps us updated so we can help you out bro
but as mentioned ..do turn speedstep off !
  #8
Old 19-08-10, 07:42 PM
Newbie
Will do. Thanks for the help.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
