OC3D Forums
OC3D Forums (https://forum.overclock3d.net/index.php)
-   OC3D News (https://forum.overclock3d.net/forumdisplay.php?f=47)
-   -   Quick News (https://forum.overclock3d.net/showthread.php?t=65782)
Dicehunter 10-10-21 08:13 AM
The 3090 Ti i.e full GA102 die, Could use a PCI-E 5.0 feature, The new power connector will enable 600 watts of power draw :o
https://www.igorslab.de/en/up-to-600...art-exclusive/
Warchild 10-10-21 09:39 AM
Watch them place the connector in the most awkward spot of all. With all power could be at the back right corner so its out of sight.
g0ggles1994 10-10-21 06:36 PM
That's absolutely insane, like needing at least 1kW for the whole system insane. I can understand those kind of numbers for workstations and professional work, but for gaming? That's just ridiculous.
Avet 10-10-21 07:08 PM
I don't agree. Flagship cards should be without limits. Give them 2 connectors for 1200W. 600W is perfectly fine. If you don't want nuclear reactor in your rig buy tamed ones. 3080, or Ti will give you close enough performance for a more reasonable power consumption.
WYP 11-10-21 08:57 AM
What I'll say regarding this is that it is ludicrous that today's GPUs use three 8-pin PCIe power connectors and that future cards could use more.
NV and AMD are working on multi-die GPUs, and on the high-end, that could mean very high power draws, especially while overclocking.
While a 600W cable seems insane, we already have GPUs with 450W power solutions. This cable needs to replace that and have additional headroom. That is why a 600W cable is needed.
We can't just keep adding more PCIe 8-pin power connectors to GPUs. We need something new.
Dicehunter 17-10-21 03:48 PM
Even though Nvidia's 4000 series isn't due until around Q3/Q4 next year, Nvidia may be halting production of the 3000 series to artificially keep prices high, Sounds fishy but it's Nvidia so I put nothing passed them.
https://www.notebookcheck.net/Nvidia....573312.0.html
Dicehunter 19-10-21 03:12 PM
The Witcher 3 next gen patch could be imminent -
https://www.kitguru.net/gaming/musta...rated-by-pegi/
Dicehunter 19-10-21 05:56 PM
Corsair are releasing a PSU 5v line balancer, Sounds like snake oil to me personally as a high end PSU should already be enough.
https://www.corsair.com/us/en/Catego...r/p/CP-8920275
https://content.invisioncic.com/p313...d46aa787af.jpg
Dicehunter 20-10-21 04:40 AM
Looks like Corsairs "Elite Series Retention Kit" for their Capellix coolers to use on Intels upcoming socket also includes a new 4 point AM4 retention bracket so you don't need to use AMD's stock cheap plastic clips, Should also give more even contact between the IHS and cooler and as it secures more firmly to the motherboard it should in theory help with slight amounts of pump vibration.
https://www.corsair.com/eu/en/Catego...t/p/CW-8960093
Dicehunter 20-10-21 08:25 AM
Zen 4 will enable laptops to have up to 16 core CPU's -
https://www.kitguru.net/components/c...p-to-16-cores/
