Zalman LQ320 with Kraken g10?
Friis
Hi there.
I am interested in cooling my GPU with the kraken g10. I have been wondering which cooler I should use to get the best result. I only have space for a single 120mm rad in my case (300R). However the thickness will not be a problem so thicker is better really. I looked around for a really thick cooler and came across the Zalman LQ320 AIO.
Does anyone have any idea of what temps I might get with this cooler on my GPU (770 Phantom 4gb)? I plan to use a single low rpm, high static pressure fan.
Also if any of you have experience with this cooler good/ bad it would be great if you could let me know.
Thank you in advance!
Sincerely
Fredrik
