FragTek
Hey yall, I have an interesting problem. I've been reading online about this cooler that I bought and some people are having similar problems, and some much more severe than mine.
However sometimes and very infrequently the fan blades will hit the cooling fins on the heatsink and make an awful noise, sometimes it lasts longer than other times as well. Is there a good/easy fix for this, or will over time the fan blade get munched down so that it stops happening?
It's really not all that bothersome because like I said it happens very infrequently but when it does happen, it's pretty nasty sounding. Kinda disappointing when you drop $70 on a HSF, it should work right out of the box without any problems like this.
Is there a good way to bend the fins just a bit so that it doesn't hit? I think I know which fins it is that the fan is touching when it happens because I've watched it while it happens and seen the fins move.
