hey guys,
I planning a new build, want a white and green colour scheme, so when i when to look for a green z97 motherboard I could fined any. done anyone know if any are coming out and if they will be DDR3 or will they be DDR4?
I seriously doubt that you will get a green themed motherboard anymore the only ones that used to do it were gigabyte but they are too busy ripping off others colour and naming schemes to make them anymore.
You could get the Asus Sabranco board which has mostly white with green and brown accents in camo looks which could work for your build here is the link to Tom's review http://forum.overclock3d.net/showthread.php?t=69274
The only ones I could think of were the Gigabyte Sniper series motherboards.
And to be honest, they didn't impress me much. If you are going for white and green theme you could aim for the Z97 Sabertooth Mark S which is a white board.
thx for the help,
i was to buy the h440 in white and black, so do you think Sabertooth and that case will be too much white and how much differences are there between z97 and z98
thx for the help,
Well depends on your cabling, fans, radiators, GPU cards, PSU etc. If these are all white then yes it will be too much. If these were a mix of black and green e.g. then no, whitecase and white motherboard would be fine.
i want green cables, still don now about fan, GPU is white and you can not see the PSU.
here a link to what i am think about buying: http://uk.pcpartpicker.com/p/w3LQxr
i want to get it down abit and still looking for some green ram sticks
