It seems I'm running 1007 bios but it says to run a much later one (1707) for 4th Gen Intel chips, which apparently the 4770k is?
http://www.asus.com/uk/Motherboards/Z87PRO/HelpDesk_Download/
I'm wondering if this is why I've had some really crappy results from AI Suite auto-over-clocking and other stuff going on.
Also does anyone know if the fan controls via BIOS are better on later versions? It seems min speeds are about 60% duty cycle while in Fan Xpert you can run much better numbers (or even off values)
Cheers
Dave
Cheers
Dave
