Z87-gd65 gaming killer networking issues
Bellows
hi, got my new board yesterday but having big problems with the killer network manager and bad lag issues, every boot i get http://s601.photobucket.com/user/Reaper_of_souls/media/Killernetworkspeedtest.png.html , when i try to use the dam program i get http://i601.photobucket.com/albums/tt96/Reaper_of_souls/Desktop_2013_11_02_10_23_01_369.jpg . i no for a fact flash is installed and adobe verified its installed as have other flash verify sites, how do i sort this problem as i'm seriously ready to remove board and send back to seller or stamp on the dam thing
hi, cheers, it helped on those to issues, but the biggest I've still noticed, my fans are always 100%, i keeps going into command center and setting them up but after reboot 100% again, when i try and save the settings it wont let me, doing me nut in
Best thing to do is getting some Molex to 5 or 7 volt fan header adaptors and run your fans straight off your powersupply. If you want to control the speeds, you'll be best off with a fan controller but those aren't needed in most cases, as long as you have decent fans that are quiet while still moving a good amount of air.
5 Volt:
7 Volt:
Both of them are available in a few different colours.
hi, i give up on the quality of the onboard killer network, its sucky pants, borrowed friends 10/100/1000 pci-e basic network card and no problem, get full up/download speeds and no lag in my game server, run onboard killer again and straight away cant give me my net speeds, ping test.net rated my connection a dam D with killer network but A with borrowed network card, any help, links to point me in any direction to fix this issue, got latest mobo bios and network driver, less lag more frag my ass, more lag less frag more like it, cheers anyway
Yeah keep trying to figure it out. My ping is lower than what it usually is with an onboard or pci-e network card. Don't know why, but it is. I get great download speeds and upload speeds. Internet Explorer and download flash from there. Only way to get the speed test to work. Also, if you haven't already double check their website (killer network) and just make sure you have the right drivers. Best of luck
