Youtube's frame cap
Josh Weston
Am I right in saying that Youtube's fps limit is set at 30fps? I've always believed this, but a friend of mine is saying otherwise - can't see anything posted by Google themselves, so I'm just wondering if any of you lovely people can help answer this for me.
Regards (from Turkey, no less),
Josh.
Doesn't Fraps work on Youtube vids? I think I remember it working but not sure, could use it to check the FPS.
it isn't about what the human eye can "see" that is like saying 30fps in games looks like 60fps because it really doesn't it is so noticeable even on a 60hz monitor and then stepped up to 120hz @ 100fps it is less noticeable but defiantly present in a side by side situation.
This made me want to find out more and it turned out to be quite hard to find good information about FPS and how the human eye perceives them. Wikipedia wasn't much help either as the section they have on it is marked as needing expert input and more information. What I did learn is that most people would definitely notice flicker at 30fps or less without motion blurring, but this does not mean you can't discern frames at over 30fps, just that as it gets above 30 you'll be increasingly less likely to notice them until it reaches the flicker fusion point. Talking about frames alternating between all black and all white, it says
the flicker fusion point, where the eyes see gray instead of flickering tends to be around 60 FPS
meaning that it would need around 60fps to not be aware of the frames. It then goes on to say that things get much more complex if you have moving objects in the scene and that the faster they move, the higher this flicker fusion point will be. More complex still is that motion blurring will lower the fps needed for smooth display.
Basically, it's definitely higher than 30fps and probably more like 60fps and above but it really depends what you are looking at and how (well) it was made.
I had no idea!
Anyway if you fancy reading it in even more detail.. and it does get quite detailed, you can find it here and here. Thanks for making me wonder!
The statement that "the human eye can see xx FPS" is total bullshed.
It various with every single person, personally I can notice a difference all the way up to around 70-80 mark, even on a 60Hz. Despite refresh rates and such forth, it's totally dependant on personal eye. However I have to say, if you don't notice a different from 23 FPS ~ 60 FPS, you got me shocked.
