It's been a while since I've asked you all for some advice but the time has come again whereby I need some of your wisdom to point me in the right direction.
It's nearly time for the yearly fluid change and I thought while I've got the loop drained why not carry out some upgrades. Firstly I want to get rid of the ghastly Tt standard rad which has been the thorn in my side for a while now and replace it with something a bit more up to the job.
Rad
Both the fans and the rad must fit into a space of ~120-125mm width by 60mm depth, 25mm of which will be taken up by my 2 existing Xilence fans (they're not the best in the world but I've got some left over from another build so I can't justify Noctuas). That leaves 35mm for the rad, possibly a couple of mm more if I stretch the fittings. I've been out of the loop (no pun intended
) so long I have no idea what to go for when it comes to rads.
A quick look at Watercoolinguk heralded only 1 result in stock that would fit:
XSPC RS360 Black - £39.99 - 121mm x 35mm
Aquatuning had a few results, only a couple of which were small enough width:
Aquacomputer airplex PRO 360 - £33.82 - 120mm x 30mm
Black ICE Radiator GT Stealth 360 - lite - £39.13 - 120 x 29.6mm
I'm assuming the aquacomputer rad would be the worst choice.
I've looked at fitting larger rads but that would involve me modifying the existing rad mounting braces (by rebending the metal and drilling new mounting holes) and I don't have the tools necessary to do so
Does anyone have an opinion as to which would be the better choice? - If you really think it would be worth the purchase of some metal drillbits and bending equipment for the larger rads please say so.
Tubing
As a side note I'll be replacing the tubing whilst I'm at it. I assume there's no real difference in performance between different manufacturers, or at least none I can make out from these:
3/8" ID - 1/2" OD Clearflex 60 Hose - £2.29
3/8" ID - 1/2" OD Hose - Clear - £1.99
Masterkleer 3/8" ID - 1/2" OD Clear - £ 2.19
Fluid
I'm assuming Feser1 is still the king of non-conductive UV fluids:
Feser One UV Acid Green Coolant 1lt - £8.09
Fans
Also if anyone knows of any 12cm LED fans which don't look like a swastika when lit up (those LED fans with 4 LEDs in the housing often tend to refract in the blades making it look a bit nazi and I'd rather the front of my case wasn't projecting that) and which aren't SilenX (I learned my lesson after all 6 of those I bought previously ended up going back when they shattered) I'd be very interested to hear from you.
Rad
Tubing
Fluid
Fans
