Hi all,
I'm in the process of a new build, but my efforts have been on hold because of my inability to decide on cpu cooling. I've got a Corsair 650D case, which i had originally planned to put the H-100 closed loop system into, but after much research, I've been scared off my the issues that many seem to have experienced.
I've been looking at the Raystorm EX240 kits with the D5 Vario pump. I will only be cooling my cpu, an Intel i5 2500K, but after six years of fighting temperatures with my current Pentium D, I want reliable cooling. I realize the XSPC system might be a bit of overkill, but the case is designed with a 240mm rad in mind, and my feeling is that with a good rad, and the D5 pump, I'll be able to run pump and fans on low settings for a relatively quiet system.
The only question for me is the new chrome Raystorm waterblock. I think that every component of the loop has the ability to give up stored heat, and the full copper block would be better at that job than the block with the plastic upper chamber, but this is my first attempt at water cooling, so my thoughts are based on good old common sense, and not practical experience, so I could be wrong!
I've watched TinyTom's videos.... Very many of them, in fact, and enjoyed them all very much. He has the ability to entertain, and pass along good information at the same time... Both important. So a big Thank You to TTL for those vids..
If anyone would like to comment on my thoughts, right or wrong, please do so. Any and all advice is heartily welcomed!
