name='PV5150' said:Because of the 'X' bracket on the back mate, it provides extra reinforcement to the motherboard to prevent warping and cracking of solder traces. It fits on the back of the motherboard, so to get at it you need to take the motherboard out of the motherboard tray.
name='PV5150' said:Thanks for the feedback guys, glad you liked it
kempez it is quite heavy, and I do lug my case around to LAN's occasionally. The XP-120 is a nice HS mate
name='Dav0s' said:you are encouraged to write your own aswella good way to gets rep points
