Mr. Smith
Summary of 'problem':
-xmnt2002 error.
-xp seemed to work fine so ignored it.
-Noticed RARE random resets.
-TONS of stability testing carried out (prime small ffts/blend etc, OCCT, memtest, rthderrytggrg lighting thing, ati artifact tool, whatever I could think of).
-System 'stable' according to all tests.
-Did a load of benching - 3dm03/5/6. Few freezes, hard locks figured it's due to pushing system hard.
-Got sick of seeing 'xmnt2002 not found skipping autocheck'.
-Removed xmnt2002 error using regedit. (partition magic line)
-Played crysis last night, cpu 3.6, ram 1066mhz 5-5-5-15, gpu stock. 1920x1200 x2 AA, NICE! Messing around. Hangs.
-Jon = sad panda.
-Tried C&C3 (not exactly demanding) but worked.
-Decided to go to bed.
Soooooo, multi-topic thread.
1. Solution/cause to problem above (that is where you lot chime in with your ideas)
2. IF the conclusion is duff file system THEN format HDD... I want new storage options. I have space for 3 HDD. Thought process is x2 250gb drives (have - though they are different makes) in RAID0 and buy a new 750gb 32mb drive for storage. May as well go Vista...
IF duff HDD THEN new HDD Raptors(waste of money?) OR 1 new matching 250gb - RAID0 and 750gb storage
3. Raid questions - do i need a raid card? I don't have a floppy for XP raid. Is it easier with vista etc.
Knock yo selfs out!
:worship:
-xmnt2002 error.
-Jon = sad panda.
Knock yo selfs out!
