FarFarAway
well here's an article from AnadTech I found to be incredibly interesting.
Its a sum of both the consoles
It basically says that if properley utilised correctly the Cell will be very good.
It says that given the right programming: the Xbox GPU will be very powerful.
It also discusses the technical vaguaries of both consoles and their hardware.
I would reccomend anyone thinking of buying the next-gen hardware to take a look. Its a long read but very interesting so take a glance over @ AnandTech
name='"AnandTech"' said:At the end of day 1, when running mostly single threaded code, the performance difference from a CPU standpoint between the Xbox 360’s Xenon and the PS3’s Cell processor is basically a wash. The 360 has more cache, while the Cell has a lower latency path to main memory. In the end, the first generation or two of games will mainly be a GPU battle between the two consoles, and both will offer significant improvements over what we have with current consoles
