HI
ill be using the noctis 450 with the x61 kracken for my 1st build, am I able to connect the x61 kracken to the fan hub then connect the fan hub to the cpu header on the motherboard ( ga-z170xp-sli) ?
I'm presuming by doing this I would be to moniter the temps from the x61 and the case temps from case fans using cam software ? also does the cam software allow me to moniter the gpu temps (gtx 980 ti) aswell or do I need to use the nivida software for that ?
many thanks in advance,looking forward to my 1st build
