x2 cores working, but not displaying properly ?
Rastalovich
One of the x2 systems I got running a very stripped version of XP, works really well, has F@H mostly going on it but sometimes it handles file movements and the odd game.
The system works well, however, out of the blue yesterday I decided to run an old game on it (Close Combat 5), and figured I could leave an F@H core running. I turned off the F@H client running as core_0 and noticed that the processor usage gauge on both taskmanager and the G15 performance display didn`t drop one core down to zero (as it`d usually do), but showed both cores cut down to 50%. i.e. two cores still showing but instead of core_1 still running at max, it showed the workload shared between the 2.
This is the first time I`ve observed this for weeks, so I have no idea of how/what/when this has happened, as with a machine working fine u don`t seem to question much.
But what`s going on there ? I`ve chucked in replacement core.cfg files to see if it was that, but it stayed the same - infact anything I run seems to be shared over 2 cores instead of one, with a fluctuation here and there - and yet 2 cores display on all testing things.
U reckon I re-application of the AMD patching lineup is in need here ?
AFAIK that's how it's supposed to work... Tried setting the affinity for the process in taskman?
Hey Frag,
Nah man, when I used to run a core, it would only fill up 1 side of the cpu meter and likewize on taskmanager (only 1 core doing the work).
Now I click on something and they both level the same just for 1 instance.
That`s another thing, affinities don`t seem to stick. Run something, assign it - run it again and it`s back to 2 cpus. Used to be able to tell something like winrar just to use core_1 or something.
Yeah, sounds strange. Normally the load gets balanced over both cores unless you manually change the affinity of a process to one of the cores. Sounds like you're on the right track with the affinities not sticking, though I don't know what would fix it. As you said, maybe reinstalling the AMD patches? There isn't a performance hit balancing over both cores is there?
Nep, re-went thru the patching process, checked the Throttle thing and it still does the same.
I can set Affinity, whilst the prog is running, and correct things like F@H to use the correct cores. However, closing them down and starting them up and I need to do it again as it`s all forgotten.
Hmm I wonder what`s going on here, my other x2 does as it`s s`posed to.. Run F@H for core_0 and only core_0 is active.
Weird.
Bah, I misunderstood. I was thinking that setting the affinity had no effect at all for you. ^^ this is what happens on my computer too.
However, if you want your computer to 'remember' the core affinity for a program then I'm sure you have to create a special shortcut or use a program like SetAffinity.
Hmm never had to do that b4 tho, set winrar to use core_1 and it would all the time.
name='Kempez' said:
I never bother setting affinity to anything. I just let the task manager do its thang
Works fine
Yeah it`s not my normal practice unless I got something that `has` to run, but something`s screwy here, I don`t know what`s going on atm. Just has another rip on CC5, and instead of core_0 filling up (game only uses 1 core), both cores filled to 50% max - wouldn`t go over 50.
Meh, I`ll see what I can come up with. Good thing is the pc is not acting up beyond this..
I`ll look at the nVidia drivers 2morrow, I read a line or 2 about some variants not getting along and so on. Bit sketchy, but was kinda the last thing I "did" to the pc (try out the latest drivers), so I`ll entertain some more reading on that.
