Wrong CPU clock speeds
lfbb
Hi all,
I'm experiencing wrong CPU clock speeds in programs like HWiNFO, TMonitor, CPU-Z. I was testing the CPU with just one core active, with prime95, when I realized the clocks did not match my multipliers, as you can see in the following images:
I did the test with 1, 2, 3 (4 is fine) active cores and the clock values of the inactive cores were all wrong. Example with 3 cores active:
The last clock speed should be 1600MHz.
MB: MSI Z77A-G45
CPU: i7 3770
Anyone has a clue on this?
Thanks
No, OC genie is for 'K' CPU's, isn't it?
EDIT: Could the problem come from the monitoring programs, like HWiNFOMonitor and so?
Maybe somebody will pop on here that knows what programs don't interact well. I saw somebody was having issues and removed all the different software and the problems cleared up. I can't find it on Google, but it was when I was surfing I ran across it.
Well, I finally figured out what was wrong, C1E enabled was the problem, TMonitor started to work well after C1E was disabled. Here is some screen shots...
1 core active(43x):
2 core(s) active(43x):
3 core(s) active(42x):
4 core(s) active(41x):
This is very strange, programs like Argus Monitor, AIDA64, CPU-Z, HWiNFO, all give wrong core clock speed values. The only that works well is TMonitor from cpuid. Go figure!...
