Wow...from 3.2 back to the 2.8 and the evap temps have gone way up again...
Brwmogazos
That 2.8M0 of mine produces so much heat my evap temps go down by a lot...
i had the 2.8 with 1.75V 24/7 and evap temps were like -51C idle at arround 4.1-4.2ghz
got that 3.2 of mine this week and at the same speed...4.2ghz i could see my evap temps get better to like -55C to -60C....with same vcore....
that higher fsb for the 2.8 is sure stressing my mach 2 GT a lot more... lol
its not all about voltage...
back with the 2.8 now and again evap temps are worse than with the 3.2 :p
The relationships can probably be explained by some simple maths...
What would be interesting to know brw is are the temps different at the same bus speeds on both chips?
i havent tried yet to check guys...
well funny enough....evap temps are at -54C with the front cover on ....
but i am only running 3400mhz now burning in my ram ehhe
i will be checking soon guys...
i noticed the better 3.2C temps when i made the little mod to prevent the metalic frame from moving inside the plastic cpu kit that goes on the top of the mobo...
