A almighty15 New member Mar 8, 2011 #2 Running Intel Burn Test on standard setting is not good, You have to run it at max so that it uses all your RAM.
M marsey99 New member Mar 8, 2011 #3 gratz mate now benchmark it to show how much free performance you have gained
S SnW New member Mar 13, 2011 #5 Garol said: The voltage is dangerously high imo. Click to expand... As long as his temps are fine , i don't see a problem at all... + its a Core2Duo ...
M marsey99 New member Mar 13, 2011 #6 65nm cpu can take much more voltage than the 45nm chips garol so its not as much of an issue.
Garol New member Mar 13, 2011 #7 marsey99 said: 65nm cpu can take much more voltage than the 45nm chips garol so its not as much of an issue. Click to expand... Thanks for the info. Im a bit smarter once again. Well actually it makes sense if u think logically. :3
