A 400w peltier
putty
2 watercooling loops (one for the peltier and one for the system)
7 SP120 Blue LED fans.
Awesome thread idea Rambo![]()
why 3x 140mm rads and not a 360 rad?
Because a 3x140mm/420mm rad is bigger!
I guess you thought i meant 3 separate 140mm rads? I mean one massive rad!
I'm pretty sure that I could get it to -20C with a 400w peltier and for just £20 it's worth it just to play around with. The problems I can see that I will face are the fact that I have to stop condensation from leaking over the rest of my hardware when it get to being that cold. What I want to try and do is either find a automatic fan controller that can handle 200w+ or find a way to make a kind of pwm for it so that it can be controlled like pwm but in terms of voltage.
If that was my build, i would use blue tack around the cpu, and special vaseline in all other places of the motherboard
World peace. :lol:
FX-9590 price to drop significantly so I can justify buying that instead of a 4790k![]()
The new upcoming R9 390x in X-fire
