Anyone know how i should be wiring up a derlin switch? Using one for power and one for reset. Also not sure on what size of resistor i should be using....
Though it could be the other way round, best grabbing some crocodile clips and checking before soldering anything.
The + - pins are for the LED.
If your 100% sure they take a 3v line not a 12v I "think" you need a 560 ohm resistor to knock the 12v down to 3v though as Jim said, you may as well run it from the mobo header which gives out 3v to start with.
I've got a couple here I need to wire up so i'll make a guide when I do it.
Plans are to use the 2 spare headers i have on the SST esa module for the led's to keep the cabling fairly hidden. Pwr will route to the psu. I'll hold on till you've had a pop at it yourself before i start getting myself in trouble.....
