name='Mr. Smith' said:
I'm more confused now than ever!
I thought
this would be ok and work but now I just don't know.
It will work fine. On the extended specs page I see:
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45 ( WAN )
4 x network - Ethernet 10Base-T/100Base-TX - RJ-45
1 x network - Radio-Ethernet
that last one is a bit odd, it must indicate the wireless interface. The one marked WAN is the port you connect a cable modem to.
I mean, do I need a cable modem too?
Yes. The router above is only a router with no modem included.
Looking at the router Virgin supplied, it has one LAN port, one USB port and one coaxial imput. The coaxial cable is the most important as this is the cable that comes out of the wall that must go into the new wireless router for me to get a the net.
The box Virgin supplied is a cable modem, I don't think it is a 'router'. A routers basic job is to correctly route internet packets to/from N computers via one external IP. eg, you have two computers A and B on your wireless network. A connects to
www.hotmail.com and B connects to overclock3d.net. According to hotmail and overclocker the same IP has connected to them, the IP of the internet connection, so they both send packets to that IP. The router will ensure all packets from hotmail go to machine A and all packets from overclocker go to B, it routes them according to the machine which requested them.
The way I have it set up at home is the coax cable goes into the cable modem, and you connect the LAN port to the wireless router's WAN port (it will be marked differently to the other 4 LAN ports). Any normal network cable will do, you get one with the router which will work fine.
Ignore the USB port on the cable modem.
Then, you can plug PC's into one of the 4 LAN ports on the router, or more likely in your case, just use wireless.
One further complication you may have is that the cable connection may be locked to a specific MAC address. A MAC address is a unique hardware identifier for your network card in your PC. Typically the cable modem picks up the MAC address when you connect it directly to your PC but as you're connecting the modem to the wireless router instead you will need to tell the router what your MAC address is.
My wireless router has a clever feature where you connect the PC to one of the LAN ports on the wireless router and using the web interface to the router click a button and it copies the MAC address from the PC to the wireless router. Then, when you connect the router to the modem, the router will tell the modem your MAC address and everything will work as required.
You can find out your MAC address by typing "ipconfig /all" in a command prompt.
Can someone just link me to a router that will 100% work with Telewest/Virgin cable broadband? Something around £30-50 that should be decent. As I only have a 4mb line I decided there is no real need for anything fancy.
Sorry for being a pita and thanks
The one you linked above will do the job. It is Linksys and I had trouble with a Linksys, once, but that's not exactly a good enough statistical sample to base a decision on.
