wireless access point
it can be used as a ranger extender
and it says you can connect 4 wired devices doesnt say that it cant do both at the same time if it is set up as a range extender whats the 4 ports on the back doing?
I've just found the manual:-
http://www.downloads.netgear.com/files/WN2000RPT/Documentation/IG/WN2000RPT_IG_07SEPT2011.pdf
Looks like it will do exactly as you want after all.
