imported_Prometheus
Hi all
First of all as this is my first post, I should introduce myself. I am actually a regular on the O-CuK forums, as are some of the poeple on here. Been overcloking for a while now and currently run on water with a LRWW setup. All on an XP-M and 9800XT at the moment.
I am in the process of planning a move to phase-change over the next month.
Thanks to advice from Phil I think I have settled on a Mach II GT for my humble needs, but I am still uncertain as to the processor.
I am mainly a gamer, so A64 is for me, but I keep hearing that there are issues with the Winchester cores at sub-zero temps. Some say this is due to mobo bios', but others say its down to the chip design. I also hear that it only affects certain chips....
Rumours were about recently that were saying that a newer updated version of the Winchester was being made and that the sub-zero temp issue would be gone...
So is any of the above true? Or am I looking at a chip based on 130nm to be certain of being able to use it on a Mach II?
Cheers
Prom
Cheers
Prom
