NeverBackDown
AMD Enthusiast
So my internet isn't exactly the greatest and according to a few runs of speedtest.net the best result i got was... Ping: 28ms, Down: 4.67Mbps, and Up:0.94Mbps. I recently came across the ability to disable Win 7 reserved limit of 20% for Windows updates and other Windows tasks.
So my question is is it really worth it? Will it help increase my speed or stability? Or in the end does it cause a lot of problems and instability issues? If it helps i have windows update set to off and i will manually check/install updates so the bandwidth limit is of no use to that.. Any help and or other advice to speed up my connection would be great
I forgot to mention I'm running wireless(would rather use homeplugs but oh well) and my adapter is far faster than what my router can provide. So it's not the connection i'm sure and upgrading the router is not an option(my parents won't).
