windows little present......
deepfried
i just love the names adware gives itself, however, look at my lateset scan result, run 20 minutes after i disabled norton to check my san andreas multiplayer settings...
at first i thought tha\t was the location of whateverit was, but no, its actually a dll in the file system :rollingla..sorry for the poor quality, i lost photoshop the other day so im havign to use paint:(
erm why not? your itnernet is internet. you may not be able to use aol browser but your net should work fine with it.
oh, dave thats the most loveliest cuddly thing about aol :) to actually connect to the internet at all on aol silver, you have to install a windows only set of drivers for the special aol bt modem, then install the aol 9 prog...which only runs on 98se and above ms systems:(
name='NickS_' said:
LOL, AOL r0x0rs the c0x0rs :rollingla
hehe, i would change to pipex, but there 1 meg a sec downlaod speeds are about the same as normal 512k downlaod speeds:( plus there support is crapy, you have to pay for everything
