Windows Explorer question
llwyd
Not made a new thread for a while :D
Was wondering if anyone knows a way to get windows explorer to default its 'view' to thumbnails. Getting sick of having to change it each and every time I upload an image :mad:
Thanks in advance guys
Ok try this...
Open Win Exploder
Set the view u want (thumbnails)
Go to Tools
Go to Folder Options
Click View Tab
Click "Apply to All Folders"
Done!
The default view is the contents of your My Documents or 'user' folder. You can change this default view to something such as the root C: (or some other path) by modifying the Explorer shortcut.
* Choose Start | Programs | Accessories.
* Right-click on Windows Explorer and choose properties.
* In the target text box, key the following: %SystemRoot%\Explorer.exe /root, C:\
* Click OK and save your changes. The next time you open Windows Explorer, it will open to the root c: as the default view. Is that what you meant mate?
Or is this it
haha dont i feel silly now
cheers frag :cuddle:
Edit: think frag nailed that one dude, cheers for the help though :)
