Windows 8.1 Key
Dawelio
Active member
Hey guys,
So I'm thinking of doing a fresh install on my PC now when I'm switching cases etc, don't ask me why though... just feel like having a fresh installed OS when not so much bs on it.
Now, it was quite some time ago I did a reinstall that I don't quite remember the key. I do have a Windows 8.1 disk and license key on hand, which I think is correct one, but I want to check my current activated key on my PC, if it's the same one. So that it will activate on it's own and I don't have to call MS and all that.
My question to you... anyone knows how to check your key in Windows 8.1 64-bit?.
Thank you,
Chrazey
Sure download keyfinder app and run it and it will give you your key then you can check it against the key you have and see if they match
