Windows 10 issue
Hi all,
Since I installed windows 10 my mouse and blue snowball mic both continue to draw power from my computer once it's switched off, the only way I can stop it is by cutting power to my computer altogether.
I have tried using different ports but get the same result, weird thing is none of my other usb devices do this. Anyone else seen this or know how i can stop it?
Yes I had a similar issue with Windows 8 it has to do with the quick boot feature but I'm not real sure how to turn it off in 10 but if you google it im sure you'll find info on it hope this helps
Thanks dude you were right, in Win 10 click choose a power plan then click "choose what power buttons do" then under "shutdown setting's" turn off "Turn on fast startup"
This worked for me.
