Windo$e rant No. 23529
Rastalovich
Why is the move command so stoopid ?
"Are you sure you want to move xxxxxxx?"
- err ok no.
"can`t move folder xxxxx as it is not empty" - ends move listing.
Why not allow the folder to be skipped for eff sake !?!?!?!?
"Cannot move file xxxxxx for whatever ghey reason?"
- err ok
... ends move listing.
Again, skip the freakin thing ?!?!?!?!
(rehousing 50 trillion gigs of music atm, wish the pc had DOpus on it)
You could probably do an xcopy from command prompt - might be a better option as I believe it skips errors (or has the ability to).
Bu yet, I find that mass annoying too :mad:
