Will this all fit together?
BamDanUK
Hey,
I previously had to box up the CPU Cooler as it wouldn't fit on my current motherboard without the ram getting in the way.
I have the Dark Rock Pro 2 from Be Quiet: http://www.scan.co.uk/products/be-q...er-with-120mm-and-135mm-silent-wings-pwm-fans
I'm thinking of getting either the ASRock Extreme 4 or 6, Haven't yet decided.
Look very similar, I suppose if it fits on one, it will on the other.
http://www.scan.co.uk/products/asro...-s-sata-raid-pcie-30-(x16)-d-sub-dvi-d-hdmi-a
http://www.scan.co.uk/products/asro...i-6gb-s-pcie-30-(x16)-d-sub-dp-dvi-d-hdmi-atx
I was thinking of getting Corsair Low Profile ram, I do like corsair and the low profile ram just looks awesome.
http://www.ebuyer.com/274035-corsair-8gb-ddr3-1600mhz-low-profile-vengeance-memory-cml8gx3m2a1600c9
Now will this all fit together without the ram being in the way?
Don't want to run into the same problem I had last time :P
Any help would be appreciated :)
Thanks a lot,
Dan
It will fit, I recently put a dark rock pro 2 on an extreme 4 with mushkin blackline and it cleared ok so you should have no problem.
