Will My Gt Fit On An A8n32-sli?
BOA279
Anyone out there have the a8n32-sli with prommy hooked up? Want to grab that bad boy but not sure if the new mobo heat pipe will get in the way. If you have your prommy hooked to an a8n32 please let me know.....pics would be bangin :D
IT does fit just to let everyone know with no problem. The only scary part is ripping the metal plate off the back of the mobo. (same as the A8n-sli) Just need to get vice grips on one corner and SLOWLY SLOWLY apply pressure until that corner starts to lift. Work your way around and off it comes. thanks for the help
