Hey guys,
I don't really know which topic this falls under but this seemed to fit it best.
I am currently running sli gfx cards and need to know if I can fit a sound card on my board. The sound card I want to fit to my board is the Asus xonar phoebus solo.
I have attached a photo below. The green blocks are where my graphics cards are and the red block is where I want to install the sound card.
My questions:
+Is there enough space there to install the sound card? I personally think that it will fit there with like 1-2mm to spare at the top and bottom. I just don't want to buy it and find out I can't fit it in.
+If I am right in saying that it will fit, is 1-2mm enough or perhaps even less okay?
+If it does fit will my top gpu run too hot?
Cheers Eddyyz
My questions:
Cheers Eddyyz
