Hi, According to the research I did no, that is not the idea. Wikipedia says it will run in the background? I also followed links to a guy at Stanford university and he also said something along those lines. What is the point in having a PC that you can only use when you are not folding? Regards
Good idea and you won't have to run it at 100% , if you don't want to ,Hi, I will try it at stock, hopefully it will work then? Thanks
Yes there is , under Configure > Advanced mateAnyway in the land of back on topic, isn't there a slider in the advanced tab of the configuration menu on the V7 client that allows you to set a CPU Percentage Usage.
