Which ones better?
jaber
I have shortlisted the Xp90c the hyper6 and the Big typhoon HS. Performance wise which one would u folks rate the best?
The Hyper6 will just about outperform the xp-90c if you fit it with 2 80mm fans, however this will be a lot noisier than the xp-90c with a single 92mm fan.
Personally i'd go with the xp-90c. I've owned a hyper6 with 2x 80mm tornado's fitted, and it made my eardrums bleed.
i agree with xms but would recomend the akasa evo 33 heatsink its very effective and with decent fans very quiet
the evo 33 sux, if you want performance but not so much noise go for the xp-90c
if you dont mind the noise then get hyper-6 with 2 tornados,
if you want to have a fried cpu from overclockign to much and no noise at all please go for teh evo 33 :)
Apparently, a lapped TT BT can beat both of those with stock fan, especially if you know the trick of stuffing the empty space with something like foam so the air from the fan doesn't escape through
