Which one should I keep?
Dawelio
Active member
Hey guys,
So quick question, which case would you keep and/or recommend me to keep, as space is limited.
Cooler Master CM 690 II Advanced USB 3.0 Version
or
Corsair Vengeance C70 Gunmetal Black
Thanks,
Chrazey
No! I'm not making important life decisions like that for you. Stick with the one you love.
JR
Haha, whaaat? :huh:... well, I don't love neither of them, but still want to keep one of them. Just don't know which one.
No love!! :o
Seriously though dude, both decent cases from reputable manufacturers. Go based on the aesthetics of whatever system you plan to put in it
No love!! :o
Haha, both look great in their own ways :p... I wouldn't have gotten either one, if they didn't ^_^
Tuff call here... anyone else that could help me come to an decision?...
Well, I throwed the C70 to the carbage and kept the CM 690 due to number of reasons.... so this thread can be closed. Thanks all for your inputs.
Woah hold up... threw it in the garbage!!? was it broken?
Surely there'dve been someone locally that could've taken a freebie?
Nothing wrong with it... and not that I know of, couldn't be bothered to anyway...
It's gone now anyway so.
You bought both of them - stick with the one that you failed on buying least =D
Not sure I get that fully... could you elaborate that please?
what he means by that is you most likely bought one then for some reason the other. So if thats the case then one failed on you for some reason or another. And since your considering which one of the 2 to keep/use, then use the one that disappointed you the least i.e failed on you the least
Of the two, I like the corsair better. I just built a PC in a Corsair Carbide Spec 03 and I liked the fit and finish.
Cheers, so was prob the right call then... but very "cloe one" though ^^
Chillax my friend, chillax :) ... I think he was just being sarcastic :) ... nothing wrong with speaking your own opinion on something, is it? :)
Well yeah I was joking but my opinion of Corsair cases is pretty low.
That's only because I've only ever used premium cases, most of which are built better than Corsair ones.
